10-14-2021
09:12
09:15
AlvaroFitbit
10-14-2021
09:12
09:15
AlvaroFitbit
how do I set my time on my Fitbit Inspire HR since i just now restarted it.
09:17
18:32
10-14-2021
09:17
18:32
@MelinaMesser I hope you're doing well!
Your Inspire HR will get the time from your phone once it syncs with it. Still if you wish you can manually select the timezone on your device but you will need to sync it.
10-14-2021
09:17
18:32
10-14-2021
09:17
18:32
10-15-2021 08:29
10-15-2021 08:29
Just figured my fit bit out problem solved I had to sync it again to get the correct time. Thanks for helping me out
07:52
18:32
10-17-2021
07:52
18:32
@MelinaMesser happy to hear that the issue was resolved. Hopefully you are already back on track getting all those steps and reaching your goals.
10-17-2021 15:24
10-17-2021 15:24
I am staying about the same on weight I lost maybe 40 pounds since two years of working out at the gym, Right now taking diet pills to stabilize and maintain my weight don't want to gain any after I worked so hard to lose those 40 pounds took me awhile to lose it don't want any setbacks to discourage me. Even If I have setbacks I will dust myself off and continue doing me and what works for me not a quitter in any means. Its always been a struggle for me to lose any weight to start with on meds that have in the past caused weight gain so I have to work harder than those who don't take medicine. To lose and maintain my weight its hard but will keep pressing on
