10-07-2020
10:39
17:44
SilviaFitbit
10-07-2020
10:39
17:44
SilviaFitbit
I have turned off all notifications for my Inspire 2, but it still vibrates periodically to notify me of zone mins and other things. I have severe anxiety and don't want it to ever vibrate because it scares me. how can I ensure it will stop?
10-07-2020 11:07 - edited 10-07-2020 11:12
Hi @carafranke
I think you want the Do Not Disturb option. You can access it through the Settings App. Please refer to pages 19-20 and page 24 for further details https://help.fitbit.com/manuals/manual_inspire_2_en_US.pdf
I hope this helps 😊
10-07-2020 11:36
10-07-2020 11:36
Thank you! I activated DND and will see how it goes!
11-25-2020 16:44
11-25-2020 16:44
I also have a problem with the vibrations. I turned off all notifications and turned on the do not disturb. How do I disable vibrations when both side buttons are pressed? I don’t know if it’s how I move my hand sometimes or what but it seems the buttons are always getting pressed and this thing is constantly vibrating.
11-27-2020 12:17
11-27-2020 12:17
@Jgolli2 A warm welcome to the Fitbit Community. Thank you for sharing what you're experiencing with your Inspire 2.
When you press the button, make sure you cover the entire button with your thumb. Note that your Fitbit device vibrates when you activate the button. If you unintentionally press the button during workouts, try moving the band higher on your wrist to get a better fit.
I'll be around if you have any additional questions.
11-27-2020 12:24
11-27-2020 12:24
Why is it not possible to turn off vibrations altogether? Mine is always on DND but is constantly accidentally going off. The vibrations drive me crazy and it’s frustrating to not be able to turn them completely off.
11-28-2020 11:02
11-28-2020 11:02
@carafranke Thank you for getting back. I see where your frustration is coming from.
Since the button is unintentionally pressed and due to this, the DND is constantly changing, try moving the band higher on your wrist to get a better fit.
Let me know how it goes.
11-28-2020 11:11
11-28-2020 11:11
That doesn’t work for me and that’s not the only instance where I get unwanted vibrations. This product is defective and the worst Fitbit I’ve ever had. I wish I had never bought it- I didn’t have this issue with the Alta, charge, or any other model. I wish I could get my money back and a better product.
11-30-2020 09:59
11-30-2020 09:59
I am having the same issues- I loved my Alta HR, it did everything I wanted. I chose Inspire 2 because I didnt want a smartwatch. I am disappointed that fitbit doesnt offer just a more basic tracker- they had to add so much stuff to this it ended up being a clunky wanna-be smartwatch that doesnt function well as either a basic tracker or a smartwatch. I really went back and forth about whether I should return it, but I dont know if the Charge or other versions would just have the same problem.
I do think I found a bit of a workaround for the vibrations though- put your tracker in the water lock mode. It will sort of turn off the touch screen and side features, but still track your steps and HR. if you want to see the screen, just double tap and it will appear as normal. To start the waterlock feature- press both side buttons and hold down for a second, the DnD screen pops up- scroll down a couple options to the water lock, and double tap to activate. Hope this helps
11-30-2020 10:54
11-30-2020 10:54
Thanks for the information! I hadn't heard of the waterlock feature, but I'll try it!
12-27-2020 18:19
12-27-2020 18:19
Hi there!
I received a new Fitbit Inspire 2 for Christmas. I had the Inspire however the battery was not holding. The new one is good, however within a few minutes of having it on, I’m very frustrated with the sensitivity of the sides. It’s constantly vibrating and going into secondary settings simply because it’s touched my skin! Wearing the tracker higher on the wrist is a temporary solution however that’s not exactly where a “watch” would be worn... hoping an update could turn off the touch vibrations or change the sensitivity!
01-11-2021 09:07
01-11-2021 09:07
I am having the same issue. The vibrating is incredibly annoying. I'm so frustrated, I was really looking forward to this upgrade. I had the Inspire HR and loved it! I don't think it's reasonable to move the device up your risk. It's quite uncomfortable. I also tried putting it on "water lock", while that solves the issue of the vibration, I can't receive any other notifications (i.e. texts, calls) or browse through any other options. If anyone can offer any advice, that would be helpful!
01-11-2021 09:55
01-11-2021 09:55
01-15-2021 06:23
01-15-2021 06:23
I'm also finding the vibrations frustrating. I have always hated haptic feedback. I turn it off on my phone--I go to great lengths to track down every single setting with a vibration option. On my inspire 2 I'm getting vibration every time I bend my wrist backwards and some skin touches the buttons.
The rationale behind the vibration is to knw whether you've made good contact with the button. But it's unnecessary. If I've pressed the button correctly, the screen turns on. I don't need two forms of confirmation that I've pressed a button correctly; I'm checking the time, not launching a nuclear warhead.
I thought I had done an adequate amount of research. I'm actually very disappointed that this isn't an option I can disable. I'm wondering if vibrating 100 extra times a day is going to impact my battery life.
01-15-2021 07:12
01-15-2021 07:12
05-16-2021 10:23
05-16-2021 10:23
It still goes off as described even with DND enabled. Its driving me crazy
05-16-2021 12:25
05-16-2021 12:25
08-08-2021 13:08
08-08-2021 13:08
So the vibrations occur when both buttons are pressed, which happens to me when I bend my wrist. Why does the action of pushing both buttons need a vibration already? If we are pushing the button intentionally, we already know what’s going on. I’ve missed so many real notifications because I thought it was another accidental notification. I hope FitBit will send an update to turn off button vibrations.
10-17-2022 20:52
10-17-2022 20:52
I’ve had the inspire 2 for a couple hours and it’s driving me crazy. I’ve tried putting it on DND, unpairing it, than repairing it, or putting it on water lock. And it STILL constantly vibrates. So irritating.
05-04-2023 07:43
05-04-2023 07:43
I started having this problem recently. I have DND on and Exercise notifications OFF. Why does it show me some progress (not sure what - steps maybe?) and vibrate. Did it when I was falling asleep a few nights ago?
