10-10-2019
20:30
05:15
YojanaFitbit
10-10-2019
20:30
05:15
YojanaFitbit
So.. I’ve had my inspire hr for a few months now and I noticed that it’s been running slow. It’s been consistently 5-7 mins behind what my phone, and the clocks at work all read. I have restarted, synced my Fitbit to my phone multiple times with either no change, or very temporary change. This is getting super irritating as I use my inspire as a watch at work.
10-11-2019 05:12
10-11-2019 05:12
Thanks for reaching out the Fitbit Forums @ChaotixParadox.
Thanks for trying those steps. That's a pretty weird thing. If your Fitbit is syncing with your phone, it should be showing the correct time. Usually, your Fitbit device's time should be changing automatically with your phone if the App has the "Automatic Time Zone" turn on in the "Advance Settings". You will find this information here: How do I change the time on my Fitbit device?
Let me know how it goes.
10-11-2019 06:50
10-11-2019 06:50
Time has been set to ‘Set Automatically’ since I first set it up. But I turned it off, synced it, turned ‘set automatically’ back on. It’s now reading the same time as my phone, we’ll see if it slips out of time again. Most of these fixes are temporary at best.
10-11-2019 13:33
10-11-2019 13:33
Hi @ChaotixParadox thanks for getting back to me. I'm glad to see that you were able to fix the time on your Inspire HR.
If you continue having issues with this please let me know. We're very interested in fixing this issue for you.
I'll be around.
09-25-2020 20:35
09-25-2020 20:35
Hello. My fitbit is displaying a 5 hour time difference. I tried all the things mentioned above. What should I do?
09-26-2020 05:19
09-26-2020 05:19
I have the same problem 2 hours difference in real time.
09-26-2020 05:24
09-26-2020 05:24
I have already sync and reset Brussels time (GMT+02:00) no result
12-14-2020 11:48
12-14-2020 11:48
how do you sync??
