01-15-2021
17:00
21:26
EstuardoFitbit
01-15-2021
17:00
21:26
EstuardoFitbit
I accidentally locked fitbit, now its unresponsive to pinch, screen is black. How do I bring it back to life?
06-30-2022 16:50
06-30-2022 16:50
Your instructions worked perfectly… thank you very much
01-15-2021 20:20
01-15-2021 20:20
Hi @Debs62 -- try restarting it.
Scott | Baltimore MD
01-20-2021 05:39
01-20-2021 05:39
what do i do
01-25-2021
04:27
08:40
01-25-2021
04:27
08:40
@mother123 @Debs62 Thanks for being part of our Community!
Let me help you with this. @Debs62 did you try the instructions that @Baltoscott shared with you? @mother123 try tapping tap the screen quickly to exit the lock. If this does work then try the restart instructions on @Baltoscott's post.
01-25-2021 04:41
01-25-2021 04:41
I did the same, a trick i found is to go into app and temporarily change your clock face, it unlocks the tracker... 😉
05-27-2022 13:01
05-27-2022 13:01
I tried tapping first because the others required many more steps and I have a lot of trouble with Fitbit. The tapping worked and I am so relieved. Thank you so much
05-28-2022
09:46
08:25
05-28-2022
09:46
08:25
Welcome to the Community forums, @Timtamabbey.
Thank you for sharing this update about the issue you experienced with your Inspire 2.
It's good to know that your device started working again. Thanks again for sharing the steps that worked for you.
See you around.
06-30-2022 16:50
06-30-2022 16:50
07-09-2022 12:45
07-09-2022 12:45
Thanks you for sharing this update @Jeffersonh!
