04-05-2024 14:19
04-05-2024 14:19
A bit of plastic has just dropped off my fitbit so that the strap will now not attach. I was just making the bed so did not knock it. Can I do anything to repair it? I don't particularly want to buy a new Fitbit but I do make good use of it. Needless to say it is just outside the 2 year guarantee period. Any advice would be appreciated.
04-05-2024 15:11
04-05-2024 15:11
Hi @SJA12 the pebble portion can still work if you put it in a "protective band cover" from Amazon. It uses that pebble piece and puts it in a band so you don't need the little clip that keeps the original band in place. Take a look and see what you think. Most are under $20
04-05-2024 15:11
04-05-2024 15:11
04-06-2024 00:13
04-06-2024 00:13
Thank you; I'll follow that up. I appreciate your help.
