06-07-2022
00:03
22:22
06-07-2022
00:03
22:22
The Inspire 2 allows up to eight silent alarms. To set a new one, one of the eight must first be deleted.
My problem is that I've never set eight alarms yet all my spots are full. Deleting one doesn't always remove it. It's very hit and miss.
Screen capture of the problem. All the alarms in the red box are not active and there is no way to delete them. They are not interactive. Deleting an active alarm often changes it to the same type shown in the red box. Help?
06-07-2022 08:07
06-07-2022 08:07
Hello @mazeman
Have you tried deleting the alarm directly on your Inspire 2? Go to your Inspire 2 and Tap “Alarms” on the Inspire 2 settings page, then find the alarm that you want to cancel or delete. Tap the trash can icon next to the alarm to delete it, or tap the alarm and adjust its settings as needed. Make sure you sync your Inspire 2 after your done to have the changes accepted.
😉 Hopefully this method of approach works for you
06-07-2022 08:07
06-07-2022 08:07
Hello @mazeman
06-07-2022 08:42
06-07-2022 08:42
@mazeman I'm taking a shot in the dark -- because you say that you can't interact with those alarms on your app. Try syncing your tracker, removing it from your account, then setting it back up as a new device. Hopefully that will clear that alarm list.
@SunsetRunner All Inspire 2 alarms and their settings are manged on the mobile app. You can review your alarms from the device. You can't set up or delete alarms on the Inspire 2 (device) alarm app.
Laurie | Maryland
07-14-2022 06:57
07-14-2022 06:57
I am having the same problem but I will add a detail. The bottom, or last, alarm listed is the only alarm I can swipe and "delete." However, all "deleting" achieves is to inactivate the alarm. It still shows up, it's just in a muted color and cannot be edited. The first alarm cannot be swiped or interacted with in any way. I have tried this when the alarm is on on the watch, when it is off, synched, not synched, and after I re-booted the watch. Thanks!
11-05-2022 19:45
11-05-2022 19:45
I have the same problem. Logging out of the app, turning off my phone and then turning on and logging back in deletes some of the “ghost” alarms, but not all of them and definitely doesn’t keep them from appearing.
11-06-2022 04:31
11-06-2022 04:31
I kept getting silent alarms on my Fitbit and I finally figured out how to stop it. I went I to my Fitbit appointment my phone, clicked on Inspire 2, clicked on Notifications and turned off what I don’t want. Hope this helps you.
