12-29-2020
08:09
21:26
EstuardoFitbit
12-29-2020
08:09
21:26
EstuardoFitbit
Water lock feature is hard to turn off. Have to double tap 20 times before it will unlock. How do I fix this?
12-29-2020 08:27
12-29-2020 08:27
@ALFSaunders Hello! I have discovered that it takes a pretty firm tap on the screen to turn it on and off. Sometimes it takes a few tries. Make sure you're tapping pretty firmly.
Hope that helps!
12-29-2020 08:27
12-29-2020 08:27
Hope that helps!
12-29-2020 10:01
12-29-2020 10:01
I also suggest making sure the screen is very dry.
Best Answer08-09-2021 08:31
08-09-2021 08:31
Hello, my problem is that I water locked it and now the screen in black or rather turned off. How do I get it to turn back on?
Best Answer08-09-2021 12:08
08-09-2021 12:08
If the unit is turned off, you will need to hold in the button to turn it on.
Alternatively put it on its plugged in charger.
Best Answer01-08-2022 13:25
01-08-2022 13:25
Very useful. It worked! Thanks
