11-19-2020 13:21 - last edited on 11-20-2020 10:41 by LiliyaFitbit
Is anyone else having problems with the pin on the band coming loose. It’s happening several times a day. I bought a replacement (on Amazon) which does the same. The pin isn’t secure once the band is attached on one side. The other is ok. I’m worried I’m going to lose the device- lucky so far that it’s stayed in my sleeve. Any suggestions?
12-30-2021 09:00
12-30-2021 09:00
Hi, I gave up eventually-as well as the band coming loose- maybe because of that- it wouldn’t track my HR or give me a sleep score so I got a refund and changed it for a Charge 4
12-30-2021 13:43
12-30-2021 13:43
Hi, I received my Fitbit as a gift. My bands won’t stay on no matter what I do. I noticed one of the interior holes for the pins to sit in is not there. More than likely this is causing the bands to not stay in place. Is there a way to fix it or do I need to just return the Fitbit?
After reading all the comments it seems like it would be best to return the Fitbit as this is an error the company cannot fix. Any assistance is greatly appreciated
12-30-2021 14:27
12-30-2021 14:27
01-28-2022 09:03
01-28-2022 09:03
I’ve had my Inspire 2 for 13 months and it started doing this last week. It’s not the bands, I’ve tried several. It’s the tracker itself, the groove/hole/side the band should insert into is stripped out. It falls off when I’m sleeping and all throughout the day. This morning it came off while I was on the treadmill. I’m goi g yo lose it. The pin design is ridiculously outdated. Reminiscent of the old watches of the 1970’s. Please send me a new tracker!
05-10-2022 13:04
05-10-2022 13:04
My husband bought the Inspire 2 for me for Christmas in 2020. My band started doing the same thing a couple of months ago. One side is fine, but the other side, the pin won't stay locked in. Bought a new band and it still wont lock in. I gave up and put my fitbit in the junk drawer, so frustrating.
05-10-2022 13:29
05-10-2022 13:29
08-07-2022 05:26
08-07-2022 05:26
We are having the exact same issue with one pin on 1 side will not stay completely In place this is causing the watch to fall off several times several times throughout the day.
This is my daughter watch and she loves it but I don't want to replace because of this simple reason and have this happen again in just 5 months.
Any help on how to fix or repair from fitbit would be helpful.
Thanks
Tim
08-13-2022 09:50
08-13-2022 09:50
Mine didn't even last a day before it popped off. Didn't notice. Found it in my laundry, thankfully before it went in the machine. No matter what I do the pin will not hold the strap on. Returning. Absolute garbage design.
08-15-2022 05:46
08-15-2022 05:46
I am having the same issue. Extremely frustrating & I have had it replaced. Same thing. Luckily I have found it twice now after losing it & not knowing. Once in the street! And another in a parking lot! All of the 100+ times I have felt it unlatch & caught it right away. Could someone please contact me??
Thank you
08-15-2022 13:10
08-15-2022 13:10
I am having the same issue. Would love customer service to contact me. I’m afraid I’m going to loose my Fit Bit. We’ve tried multiple replacement bands with no luck. Has anyone heard back from Customer Support?
08-15-2022 13:27
08-15-2022 13:27
I have not yet. And I cannot find a valid # to call 😞
08-15-2022 17:35
08-15-2022 17:35
Update….I found my Fitbit wedged in underneath the. Front seat of car. I purchased a new band and then it continued to happen. I then lost the pin, but not the Fitbit. I ordered a replacement pin kit and have gone thru several pins….but have been ok for almost 2 mos. Still don’t understand why this keeps happening, but glad that I still have it at the moment.
08-25-2022 12:35
08-25-2022 12:35
I am having the same issue - just got replacement band today and it popped off twice already within 20 minutes. The pin will not hold and they are new pins.
08-30-2022 13:02
08-30-2022 13:02
Having same issues with band coming off. Tried to ensure pin in locked but looks like plastic gets worn and no longer holds after a few months in our case
09-03-2022 15:51
09-03-2022 15:51
Yes!! I am having this same problem, one side clicks in and stays firmly while the other side continues to pop off! Very frustrating
01-10-2023 13:10
01-10-2023 13:10
Hi Liliya,
Tried to reach out on email and page kept erroring.
Received an Inspire 2 for Christmas and the band keeps coming off even with the slightest tension, almost as if the pin isn’t locking in. Even tried the other sized strap and still the same issue. I am worried I am going to lose the watch if it carries on.
01-13-2023 10:00
01-13-2023 10:00
I'm having this same issue, glad to know I'm not the only one. I've replaced pins, and bands and I've even switched how the bands were. It continually pops off, my inspire 2 is only about 8 months old. My sister and I bought them at the same time, she got the inspire 2 and I got the Luxe, she didn't like the side touch and asked to switch trackers; most of the time I don't notice it. I wish I had never switched, it doesn't matter what I do the band comes off only on one side. The pin is always secure, I have switched between several different clasp bands in those 8 months due to texture issues with no problem until now. I have now lost 3 different pins due to it popping off and am running out or replacement pins. I'm fed up and don't know what to do now.
01-15-2023 08:15
01-15-2023 08:15
A Christmas present from my daughter. When it stays on, I really enjoy this product. Swapped the shorter band for the larger size. The thing keeps falling off at different intervals and different situations. I’m fortunate that I haven’t lost it. Please provide us with some help!
05-01-2023 18:22
05-01-2023 18:22
I am having the same problem. The pins will t stay in. What can be done?
05-01-2023 18:26
05-01-2023 18:26
