01-07-2022
05:59
22:58
01-07-2022
05:59
22:58
I've had my inspire 2 for almost a year and all of a sudden the sensor buttons to wake the watch don't work unless I press hard. It's extremely frustrating anyone have a fix?
01-07-2022 13:48 - edited 11-18-2024 06:14
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2. I understand how you must be feeling.
Is it possible the Water Lock feature was accidentally enabled? That will lock up the screen and side buttons. If that describes your issue, please firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
Hope that helps.
Best Answer01-07-2022 13:56
01-07-2022 13:56
Best Answer01-07-2022 16:41 - edited 07-21-2023 03:45
@SunsetRunner I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
