04-19-2023 11:35
04-19-2023 11:35
I have already contacted Tile, and it is not their issue. The fitbit has been removed from the account attached to the broken phone, but still shows as connected. Restarting the fitbit does not change anything. There are no issues connecting to the Fitbit app. Any ideas? The old phone is not salvageable at all.
04-19-2023 11:47
04-19-2023 11:47
Disregard, erasing the fitbits data worked to reconnect.
04-19-2023 11:47
04-19-2023 11:47
04-19-2023 12:28
04-19-2023 12:28
@rkha , A warm welcome to the Community! Thank you for your message and for sharing the solution that worked for you .
I marked it as Best Answer, so others with the same situation, can find your suggestion easier.
