02-08-2021
05:04
21:26
EstuardoFitbit
02-08-2021
05:04
21:26
EstuardoFitbit
I just did a 20 minute set of yoga / Hiit and it didn't log any information.
02-24-2021 07:03
02-24-2021 07:03
Hello @annemariebrody, welcome to the community forums! @LZeeW, it's great to see you around and thanks for your input!
@annemariebrody, I was able to that @LZeeW provided information about your inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
See you around.
02-08-2021 12:50 - edited 02-09-2021 04:07
Hello @annemariebrody and welcome to the Help forums. Please correct me if I am wrong. It sounds like you did this workout using the auto-recognition feature (SmartTrack). Yoga doesn't have the motion frequency to be auto-recognized. You must use the Exercise app with the yoga shortcut for it to get tracked. The HIIT portion of your workout should get recognized as Aerobic Workout, or sometimes Sport, but the default minimum time to recognize any activity is 15 minutes. If your HIIT was less than 15 minutes, then that explains why it didn't track anything. I think these will help you: How do I track my workouts with my Fitbit device? How do I track my activity with my Fitbit device?
If you have any more questions, we're here to help.
Laurie | Maryland
02-09-2021 05:20
02-09-2021 05:20
02-09-2021 09:23
02-09-2021 09:23
@annemariebrody There is a section in my first link that has the instructions for customizing the exercise shortcuts. Here is a link to a very good YouTube video that shows the steps. This will work for any Fitbit where you customize the exercise shortcuts in the phone app.
From your description, it sounds like you did some, but not all, of the steps to start the exercise app.
Laurie | Maryland
02-12-2021 10:45
02-12-2021 10:45
Thank you this has worked now.
02-24-2021 07:03
02-24-2021 07:03
See you around.
02-24-2021 08:19
02-24-2021 08:19
02-25-2021 05:00
02-25-2021 05:00
@annemariebrody, thanks for your reply!
Note that you can post through this thread or create a new if you have additional questions or inquiries.
Have a wonderful day!
03-02-2021 12:32
03-02-2021 12:32
Thank you. That is helpful. Thanks to you I can start it logging my exercises but it won't stop. I press the sides and it goes to DND. I keep pressing it and eventually it seems to have an arrow up on the screen that says press to stop but it just goes back to DND. Sometimes randomly it seems to finish.
03-04-2021 04:15
03-04-2021 04:15
Please ensure that your Inspire 2 is worn properly on the wrist (2-3 finger widths from the wrist). If the buttons are pressed unintentionally this could be the reason why DND mode turns on. Also, water lock feature could be turned on if it's in contact with water as it can activate the button.
For tips on how to change your settings back, check this article. I also recommend visiting the following thread for tips and updates.
Hope this helps!
02-08-2022 17:25
02-08-2022 17:25
Was there an answer here somewhere? I didn't see one. I just did a 20 minute aerobic exercise and it did not auto-detect, and it would not let me log it. It keeps saying that I'm logging it in a future date/time but I am not.
I'm wearing it properly according to what I read.
