02-01-2022
20:34
22:54
02-01-2022
20:34
22:54
Fitbit flex was fine. Inspire 2 does not consistently buzz to give reminders to move but has suddenly started buzzing me when I get a text. I don't need that.
02-20-2022 17:46
02-20-2022 17:46
I'm having that issue, too. The movement buzz randomly shuts on and off and I can't figure out what causes that so I can fix it.
Best Answer02-23-2022 13:02
02-23-2022 13:02
Same with me. No movement reminders (even though they are enable) and no notifications when texts come in (also enabled).
02-23-2022 15:39
02-23-2022 15:39
Mine NEVER gives reminders to move. I hate that. I loved the encouragement from past devices. It was really helpful
Best Answer02-24-2022 04:50
02-24-2022 04:50
Best Answer02-24-2022 08:46
02-24-2022 08:46
What instructions did you use that worked??
