05-17-2021
16:16
23:01
05-17-2021
16:16
23:01
My app updates but my Inspire 2 does not show data for sleep (says no data), days of exercise in the week and something that says no score. Looks like Apple watch will be coming up soon. 😞
05-17-2021 17:24
05-17-2021 17:24
NO need for an Apple Watch! You just need to sync!!!
I had that problem too, but turns out, my Inspire 2 was too far away from my device to sync! Now, your Inspire 2 does track your sleep even if it says "No data", you just need to sync to change it.
05-17-2021 17:26
05-17-2021 17:26
It also tracks other things but they need to basically be "converted" to display the amount you worked out, and your sleep score (yes, the "no score" thing is your sleep score).
05-17-2021 17:48
05-17-2021 17:48
not sure how to synch they dont make it simple
05-17-2021 17:51
05-17-2021 17:51
Umm. Syncing is pretty simple. Just go to the app, click on your account profile (in your case a person with a sky blue background), choose the device, and click sync.
05-17-2021 17:52
05-17-2021 17:52
It also syncs every 15 mins or so I think. Also, your Fitbit and the device you have the Fitbit app on has to be in a 100-foot range.
Hope this helped.
05-17-2021 17:53
05-17-2021 17:53
05-17-2021 18:28
05-17-2021 18:28
Huh. Well, make sure your Bluetooth is always on, which it probably is, and I guess there's a sensor problem or something? There also is no guarantee that Apple Watch is better than Fitbit.
05-17-2021 18:54
05-17-2021 18:54
@French_Fries !Nice to see you around. Thank you for your help and tips.
@pleaseeee @French_Fries ! A warm welcome to the Community! Than you for your efforts and information.
@Judy_C : Please follow out these steps, you have already done some, but the order is important:
Hope this helps
04-09-2022 06:42
04-09-2022 06:42
This worked for me. Thanks!
04-09-2022 13:32
04-09-2022 13:32
The watch face no longer lights up when I rotate my wrist and it doesn’t respond when I push the side button to try to reactivate it. Also several weeks ago my Zone Minutes stopped working. I have synced, turned off Bluetooth and phone and then restarted them according to your instructions here, but nothing I’ve tried makes any difference. I do have Assurion coverage but am trying to avoid the hassle of that process. Can you help?
04-10-2022 18:41
04-10-2022 18:41
@Hubblanc , Nice to see you here. Thank you for your message and great news. I'm glad that the information helped you.
@husker2cat , Thank you for your message and for trying the steps recommended.
Does the tracker light up when you tap on it?
If so, can you move the screen between menus?
If positive, please swipe until you see the settings, and tapp on it again.
Verify there that the don;t disturb and sleep settings are off. To change them, just tap on it.
See you around.
