01-09-2022
19:33
22:58
01-09-2022
19:33
22:58
I would like the inspire 2 to allow me to remove, add, or rearrange the order of the apps on the screen. It's a bit silly that I need to swipe multiple times just to see my heart rate. I did see the response for a similar forum, but it is honestly quite disappointing that this feature has not been slated for work since 2019 when the first post was created for it. Publically release the code and I'll fix it for ya. It can't be that many coding man-hours. Even if it's just a reordering of the apps. Should just be in a list object of some sort. It's the small details that make products great and this product, though newer, is not better than my old Alta HR from 2017 for this sole reason. It's silly Google.
I apologize for the sassy response, but seeing this as a problem since 2019 is ridiculous as I am a programmer myself.
01-10-2022 09:18
01-10-2022 09:18
I got a response that says to press and hold app in screen til.it increases in size then drag to new location. Can't get that to work either. Agree should not have to scroll to see HR.
