Inspire 2 doesn't have Miles to Kilometers
ANSWERED
Hello,
My Inspire 2 does not have an option under 'units' to change from Miles to Kilometers.  It only displays length, weight and water.  Is there another option?
1 BEST ANSWER
Accepted Solutions
Ok I included screenshots of exactly where you need to go:
 This is the top of your Dasboard when you open your app. Go to your Account Settings, which I've indicated in red.
 Your Account Settings page should look like this. Find "Units".
 This is your "Units" menu. Select "Length".
 This is the final step. Select "Kilometers" and hit "Ok".
one cruise ship at a time!
7 REPLIES 7
Hi @MichWalk,
There is a way to change to kilometers, but in order to give you the correct navigation to that point, we need to know which OS you're using.
Android for phone and Windows for laptop.
Ok @MichWalk, I have both of those.  Which one do you use to sync your device?
Android phone.
Thank you so much. 🙂
So easy, once you know where to look. 👍
I just want to add that the iOS path is exactly the same.  The screens just look different.
Laurie | Maryland
