10-04-2020 23:10
10-04-2020 23:10
I find myself trying to see the screen, imaging that!!! But I can’t get the screen to wake. It’s wakes with my wrist turn but I have to exaggerate my turn or sometimes try again.
I have given on on double tapping. It no good.
10-07-2020 11:48
10-07-2020 11:48
@Willslawrence It's nice to see you in the Fitbit Community! Thank you for getting in touch about this.
The double tap function will turn your screen on but it must be off for at least 10 seconds for this setting to take effect. Regarding your screen not turning on when you turn your wrist, please check that this setting has been activated by going into your 'Quick Settings' (press and hold the buttons on Inspire 2) choose 'Screen Wake' and turn it on.
Let me know how the troubleshooting goes. I'll be around if you have any additional questions.
10-07-2020 12:09
10-07-2020 12:09
10-08-2020 07:24
10-08-2020 07:24
I am frustrated with same issues. I have checked and rechecked my settings, restarted and resynced several times. Wake screen And double tap hardly ever work. I always have to push buttons.
Also, rode my bike 17 miles Tuesday, peak zone 44 minutes and cardio zone 33 minutes and showed I burned 153 calories!!!
10-08-2020 16:24
10-08-2020 16:24
@Willslawrence Thank you for getting back. Your comments are appreciated, I completely understand where this frustration is coming from.
Please restart your Inspire 2 and continue monitoring its behavior after this.
@Lzinck Welcome to the Fitbit Community. Thank you for the troubleshooting tried prior to posting.
Since you have checked your settings and restarted the tracker but still experiencing this, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
In regards to the data that's being tracked by your Inspire 2 please make sure that your personal information is properly entered in your account, learn more about it by checking this article: How does my Fitbit device calculate my daily activity?
10-10-2020 10:11
10-10-2020 10:11
10-10-2020 15:30
10-10-2020 15:30
In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
10-11-2020 17:07
10-11-2020 17:07
I pinch both sides to get it to wake.
10-12-2020 07:40
10-12-2020 07:40
Yep, me too.
10-13-2020 13:34
10-13-2020 13:34
@lurleblanc @CarolynCJ It's nice to see you on the Fitbit Community. In order to wake up the Inspire 2 you'll have to press both buttons. If you'd like to use the double tap function, please confirm it's turned on by doing the following:
From the clock screen, swipe down and open the Settings app Tap the "Double Tap" setting to adjust it.
10-13-2020 16:53
10-13-2020 16:53
10-14-2020 12:15
10-14-2020 12:15
@CarolynCJ Thank you for getting back. I'm glad to hear that it's back to normal after you changed the band.
Happy stepping! 😎
10-14-2020 20:17
10-14-2020 20:17
I have so many issues that are listed here. I also can't stand that just by moving my wrist I'm waking up the device by my skin coming in contact with the sensors on both sides which results in settings getting messed up all the time.
I kinda want to see if I can return this and go back to my Alta HR.
12-07-2020 20:45
12-07-2020 20:45
I just purchased the inspire 2 mainly for all day heart rate monitor and to replace my simple digital watch. Also liking the sleep tracking. I also wish there was a setting to have the screen stay on all of the time for when I want to use it as a digital watch. I am experiencing everything you described in this post. The wake works maybe 80% of the time and I often have to re try and doing that many times a day had already gotten very old. Also have issues all day with the double tap not working. And same as you with the water mode. It takes trying multiple times to get out of it. I think if there was a setting to have the screen on all the time it would fix at least the wake and double tap issue for me. And I wouldn’t mind having to charge it more often. So I’m not sure if I’m going to look into returning it. I love all the features and wish the screen and navigating was better and more user friendly.
12-07-2020 20:48
12-07-2020 20:48
Also I’ll add that I have watched videos, read all of the information on the website about how to navigate and use the inspire 2 and have done everything mentioned by the moderators in the thread. I was really hoping it would be a quick fix but from reading from others it seems like it’s just the device 😕 please fix this I wanted to love it! 🙂
02-15-2021 18:32
02-15-2021 18:32
A week ago, I returned a brand new Inspire 2 as the double tap function wouldn't work at all. Went through the whole trouble of doing a factory reset and spent hours with customer service trying to solve it. I figured that I had just received a defective device. So, I went out and bought a second one and now less than a week later, the double tap function on this second device is also not working. This is clearly an Inspire 2 defect that FitBit needs to fix.
03-04-2021 23:10
03-04-2021 23:10
The same problem reported in this thread. I got the Inspire 2 for less than a day and I am already noticing trouble with double tap. I used to have Alta and it always responded to double tap. On the other hand, I have to tap Inspire 2 multiple times to turn on the screen.
I am thinking of returning it and waiting for a new model!
03-05-2021 08:38
03-05-2021 08:38
Please remember that the screen is a touch screen. A simple double touch is all that is needed.
This touch should be no different than the touch used while typing a text message in the phone.
The harder the user hits the screen, the less likely the display will turn on.
For screen wake with the rotation of the wrist. Hold the forearm somewhat horizontal, the angle seems to be within 30° of horizontal. Then smoothly rotate the wrist 90°. No jerking should be needed and would again be counter productive.
03-05-2021 13:51
03-05-2021 13:51
I tried different double touch strengths and speed. Still, it is vastly inconsistent. There is a big difference between the consistency of the Alta and the inconsistency of Inspire 2.
12-01-2021 19:13
12-01-2021 19:13
I also found the watch worked better with the wrist turning after I put on the longer wristband. Maybe it was to tight on my wrist. Although the double tap still does not work ?
