10-03-2024 22:51
10-03-2024 22:51
Hi there, I'm trying to re-pairing my inspire 2, but when it goes to the matching page which I need to input the 4-digit pin shown on the device into the app, I am not able to do so as it stuck on the first digit .
My phone is Iphone SE2 , most updated ios
As shown as below:
https://drive.google.com/file/d/154JMMv0iFtVA_yKRoKfOlWuEWewXHIN-/view?usp=sharing
10-07-2024 00:01
10-07-2024 00:01
I have found the solution by myself which is to change the app's language to English instead of other languages ( it was Chinese in my case), I guess this issue is due to the capability of input interface between ios and the Fitbit app.
10-05-2024 06:40
10-05-2024 06:40
Best Answer10-05-2024 12:04 - edited 10-05-2024 12:05
Hi there @Vincentli and @remarithalei! Welcome to the Fitbit Community!
Thank you @Vincentli for letting us know about the situation you're having trying to pair your Inspire 2 and for the video.
Have you tried to restart your phone and Fitbit, to delete the Fitbit app and to log out/in?
I suggest you try the steps from this article too: Why can't I set up my Fitbit device?
Best Answer10-05-2024 21:28 - edited 10-05-2024 21:32
Hi,
thank you for your reply, I have tried every steps you mentioned.
I also tried to pair with the other iphone SE of mine, it has the same issue.
However, I can successfully paired it with my ipad.
So I guess it is the compatibility issue of iphone SE and Fitbit's app.
Best Answer10-07-2024 00:01
10-07-2024 00:01
10-08-2024 09:27
10-08-2024 09:27
Hi @Vincentli!
Thank you so much for sharing the solution with us. I am very glad that you could solve the issue.
Thanks for being part of our Community!
