10-10-2020 16:53
10-10-2020 16:53
I'm interested in getting back in to using a fitness tracker, but I'm wondering if new tech has overcome the problem that made me give up my Charge HR so quickly back when it came out.
The problem Is that the trackers are all too big for my tiny wrists. It's true they'll tighten enough, but the length of the bulk of the device extends beyond my wrist so there is always an awkward gap. Is the inspire series at all an improvement in this regard?
Best Answer10-10-2020 17:39
10-10-2020 17:39
Hi @Splatteredwhim the Inspire 2 has an optional clip that might suit your needs. You can wear it on your waistband, a shirt pocket or tucked inside a bra. You might want to look at it - click to view.
Best Answer10-10-2020 18:21
10-10-2020 18:21
I did notice the clip option, which seems pretty cool. But it doesn't seem like you can use the heart rate functions with it Is that correct, or is there some place I can clip it and still get heart rate measurements?
Best Answer10-22-2020 09:55
10-22-2020 09:55
The Charge HR is definitely a lot bigger than the Inspire. I think you will like the Inspire better. I find that the Inspire fits small wrists a lot better and the device doesn't extend beyond the wrist.
Best Answer11-28-2020 07:17
11-28-2020 07:17
Well I finally went ahead and got one, but the truth might be that I'm just too small for activity trackers. Here's how it gaps on me. It looks great on my husband though. I'd be ok with a clip-type if it weren't that I also wanted the heart rate info. Undecided if I'll keep it or not.
12-06-2020 07:46
12-06-2020 07:46
I have the same issue as you do, the small wrist. I did buy a cheap fabric band from Amazon that doesn't curve our like the silicone ones do so it's not quite as bad.
07-21-2022 09:03
07-21-2022 09:03
I bought a flexible wristband which seems to help but it's still too big for my wrist.So big!
