11-09-2023 15:45
11-09-2023 15:45
I have an Inspire 2. When I start an exercise (biking or hiking), the fitbit successfully connects to my Android phone to use its GPS and correctly starts measuring the distance and creating a GPS track. However, at some point during the exercise, it stops measuring distance for 30 minutes and then starts working again. When I look at the track, there is just a straight line connecting the point prior and the point after the 30 minute hiccup. So, both my distance and track are not correct.
Any ideas as to what may be causing this?
11-12-2023 19:30
11-12-2023 19:30
@JPeterO , Thank you for your reply and confirmation.
Please make sure that the Fitbit app is allowed to run in the background. ( Even with the phone's display off)>
The setting can be found at the app battery consumption menu on your phone.
Best Answer11-09-2023 16:40 - edited 11-12-2023 19:28
@JPeterO , A warm welcome to the Community! Thank you for your message
Best Answer11-09-2023 17:34
11-09-2023 17:34
Yes, GPS is turned on (settings -> Phone GPS on) and the phone is with me so within a few feet of the Fitbit - and I make sure that it tells me connected before I start.
As I noted, I'm using an Android, not an iOS phone.
Best Answer11-12-2023 19:30
11-12-2023 19:30
Best Answer11-13-2023 12:42
11-13-2023 12:42
This may be the solution. The 30 mile bike ride I did today was completely recorded - it had a full GPS track with no gaps or 30 minute missing pieces. I still want to do more outdoor exercises to confirm the suggestion about making sure the Fitbit app will run in the background works. I will post what I find in a few days.
12-02-2023 13:39
12-02-2023 13:39
After logging several activities (both hiking and cycling), it does appear that the suggestion to allow the Fitbit app to run in the background fixes the issue. I also found another setting related to this - under battery, advanced settings, optimize battery use, I set it to "Don't optimize" for Fitbit. This is in addition to the setting under Apps, App Management, Fitbit, Battery usage - allow background activity. Don't know if both are needed, but I have them both set so background activity won't be compromised.
I did have one workout where it missed 30 minutes of the track, but I'm going to say that was a fluke since all the others have 100% of their GPS track.
12-03-2023 17:35
12-03-2023 17:35
@JPeterO , Thank you for keeping us updated. I'm glad that the information was helpful.
Please visit our discussion forums. There you will find several users who are interested in fitness, healthy eating or better sleep and share lots of tips. They will be happy to meet you there.
