07-08-2023
11:05
18:54
AndreaFitbit
07-08-2023
11:05
18:54
AndreaFitbit
My inspire 2 is dark all the time. Won't light up at all. Still works fine and does what I want it to do.
I wondered if there is a brightness setting somewhere that I might have missed?
07-09-2023 02:55
07-09-2023 02:55
Hi, @DB1974 , yes, there is a brightness setting, and if it has gone to “dim” you will need to go into a very dark room to see it! From the clock face screen (if you can see it!) keep swiping down until you come to the settings menu. The first item on the settings menu is “Dim screen”. Tap to turn it on or off.
I hope this helps. Welcome to the forums!
07-09-2023 07:00
07-09-2023 07:00
I have Dim set off and cannot see the display in sunlight. Really makes the device useless! Very disappointed.
Best Answer07-09-2023 08:11
07-09-2023 08:11
Hi, @SunsetRunner , yes, the visibility in sunlight on the Inspire and Inspire 2 is an often reported complaint. I am afraid there is no fix for that other than stepping into the shade.
I can confirm that the newest model, the Inspire 3, does not have this issue. It has a lovely bright colour screen (as does the Luxe and other newer Fitbits - the technology has improved a lot, even since the Inspire 2).
Best Answer07-09-2023 08:19
07-09-2023 08:19
I only bought it yesterday so think I’ll return it as that brightness is no good to me.
Best Answer07-09-2023 08:29
07-09-2023 08:29
If visibility in bright sunlight is an issue for you then it makes sense to return it, as there is no fix for this, as I said. I would very much recommend the Inspire 3. You will not have any visibility issues with that one.
