03-28-2024
17:05
20:48
03-28-2024
17:05
20:48
Hi my Fitbit inspire 2 is not showing the sleep stages and the sleep tracking looks way off because 1 time I slept 9 hours and today I slept 5 hours and I have Fitbit premium also if this helps I use the begin sleep now option. That is all thanks
03-28-2024 17:42
03-28-2024 17:42
@SunsetRunner in order to get full sleep data, you need to let your Fitbit detect sleep automatically. If you use the "Begin Sleep Now" feature, you will only get simplified sleep details. Instead, just go to sleep and let your Fitbit figure it out for itself.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
03-28-2024 20:53
03-28-2024 20:53
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your sleep stages. We're here to help you!
As @alexthecat has pointed out, if you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed), this would explain why you're not getting your sleep stages.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern.
03-29-2024
04:56
04:25
03-29-2024
04:56
04:25
Thank you for the info I will use it today I will reply back after my sleep
Update: I’m back it worked thank you
03-29-2024 17:07
03-29-2024 17:07
03-30-2024 04:25
03-30-2024 04:25
@SunsetRunner I'm glad to hear that the recommendations we provided did the trick. Thanks for sharing the outcome!
In case you have some spare time, I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
03-30-2024 05:34
03-30-2024 05:34
Ok I will post if I need anything but now it’s going great
04-01-2024 16:09 - edited 04-01-2024 22:01
@MarreFitbit Hi my Fitbit is stuck on screen I can’t move it
04-01-2024 22:03
04-01-2024 22:03
Oh nvm I fixed it by changing the clock face
