10-16-2024
08:16
10:59
ManuFitbit
10-16-2024
08:16
10:59
ManuFitbit
I have searched the app on my phone but there is nothing about fixing this problem. Please help. Thank you
Moderator edit: clarified subject.
10-20-2024 10:04
10-20-2024 10:04
@1975tn The Do Not Disturb setting doesn't change your screen brightness, but being in Sleep Mode will set it to dim. But it should still be readable without having to go in a closet and shut the door to see the screen. If you can't read the screen in a completely dark room, then I think you have a screen failure. Sorry.
Laurie | Maryland
Best Answer10-16-2024 10:54 - edited 10-16-2024 10:54
Hi @1975tn. Welcome back to the community.
Thank you for providing the details regarding your Inspire 2 and for trying to fix it on your own.
Please, check if you have the Do Not Disturb mode on. Also, make sure the Sleep Mode setting isn't enabled. For instructions, refer to How do I navigate my Fitbit device?
10-18-2024 10:28
10-18-2024 10:28
Thank you for replying. I can't find anywhere on the app about Do Not Disturb. Neither can a see anything about Sleep Mode. Sleep isn't being tracked. I can only see tracking on the app on my phone as it is impossible to read details on the Fitbit
Best Answer10-18-2024 15:18
10-18-2024 15:18
Thanks for responding @1975tn.
Do Not Disturb feature is located in the device itself. Please press and hold the buttons on your Inspire 2. Once the menu appears, tap "DND" to toggle it on or off.
To check if Sleep Mode is on please press and hold the buttons to access quick settings.
Sleep mode turns off automatically when you set a schedule. To set a schedule:
You can't turn on do not disturb and sleep mode at the same time.
10-19-2024 04:33
10-19-2024 04:33
Thank you for replying. As I said in my initial post, the screen on my device is almost black and I am unable to read anything.
Best Answer10-20-2024 10:04
10-20-2024 10:04
Laurie | Maryland
Best Answer10-20-2024 11:58
10-20-2024 11:58
Hi and many thanks. Now, why didn't I think of that. I took it into a dark cupboard, and with a magnifying glass managed to fix the problem. Not sure how the screen came to be on dim.
