04-15-2023
21:37
07:49
04-15-2023
21:37
07:49
My Fitbit inspire 2 screen is bright in the dark & I can't see it at all in the light.
Please help!
Thanks!
04-17-2023 07:50 - edited 03-17-2024 08:49
Hi there, @rjgurley. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the inconvenience with your Inspire 2.
Please restart your Inspire 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If none of the above works, please check if by any chance your Inspire 2 is in sleep mode. When the sleep mode setting is on:
For more information, see How do I navigate my Fitbit device?
Best Answer04-17-2023 07:50 - edited 03-17-2024 08:49
Best Answer04-17-2023 20:51
04-17-2023 20:51
I had this same problem sadly nothing fixes it. Its great indoors but it’s meant to be for fitness which is often outdoors 🤷🏼:female_sign:
