Inspire 2 is tracking too many steps
ANSWERED
My bit counts 3,800 Steps in the 30 minutes it takes to get dressed and dry my hair in the morning. It will also Count 1000 Steps while I am Driving 3 miles to work.  I am right handed and wear it on my Left wrist. Thanks
1 BEST ANSWER
Accepted Solutions
Hi there, @OhDeer64. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Inspire 2 is tracking too many steps. Thanks for the details provided in your post, I will do my best to help you with this.
As a first approach, I'd suggest to confirm that the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see How does my Fitbit device calculate my daily activity?
Also, please keep in mind that excess vibration might cause extra steps. Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps.
If the above doesn't describe your issue, by any chance, d
o you have MobileTrack also linked to your Fitbit account? If you do, please note that MobileTrack could be tracking those extra steps. To verify this, please in the Fitbit app, tap the Today tab > then tap Devices. In this section you'll see your Versa 3 and below your phone (in case MobileTrack is indeed connected).
If the above describes your situation, you can remove MobileTrack by tapping on the phone's icon and then select "Remove From Account".
1 REPLY 1
