06-01-2023
08:31
11:21
06-01-2023
08:31
11:21
For the past week, my running distance increased suddenly from 5 km to 8 km - even though it is the same distance as before. When I checked the GPS map after the work out, I saw that the lines are totally wobbly, probably adding the additional kilometers. The GPS worked perfectly for two years. No idea what happened in the last week! Any suggestions?
Moderator edit: clarified subject.
06-01-2023 10:13
06-01-2023 10:13
Hello @Rhuget and welcome to the Community. Your Inspire 2 uses connected GPS, using your phone's GPS. When you get wobbly lines, it usually means a phone setting issue. Please see this Help article for troubleshooting steps. Make sure you aren't in a power saving mode, things like that.
Laurie | Maryland
