07-18-2023
01:14
04:16
07-18-2023
01:14
04:16
My inspire 2 only shows daily steps, doesn’t log heart rate, sleep or anything else
07-18-2023 04:19
07-18-2023 04:19
Hi there, @Shazza730. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2.
To better assist you, please confirm if the data missing is from your Inspire 2 itself or the Fitbit app? If the data is not showing up on your Inspire 2, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
However, if the data is on your Inspire 2 but not syncing with the Fitbit app, please see Why won't my Fitbit device sync?
Best Answer07-18-2023 04:19
07-18-2023 04:19
Best Answer07-27-2023 06:19
07-27-2023 06:19
I’m having the same issue and restarted my device already. Restarting didn’t cause my Fitbit to start working correctly.
Best Answer07-27-2023 06:24
07-27-2023 06:24
I just changed the clock face and will let you know if this works.
Best Answer07-27-2023 11:50
07-27-2023 11:50
Hello, I’ve restarted my device and changed my clock face and my Fitbit still isn’t tracking anything other than steps. What should be done from here?
