Inspire 2 - might be stuck on water lock
My inspire 2 has stopped working think its water locked
Moderator edit:  updated subject for clarity
3 REPLIES 3
@WAWAFEET1 , A warm welcome to the Community ! Thank you for your message.
If the water lock is on on the Inspire 2,  tap firmly your screen twice to deactivate it.
Or if needed try to restart your Inspire 2
  1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  2. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  3. Press and hold the button or buttons on your tracker for 5 seconds.
  4. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
My fitbit does not vibrate after reboot, I get the smile.
@makto , A warm welcome to the Community! Thank you for describing what happens after the restart.
The smiley shows that the restart was successfully.
What do you see on the screen when you firmly double-tap the middle of the screen with your finger? If you don't see "Unlocked" appear on screen, try tapping harder?
