Inspire 2 no longer vibrates for calls and notifications
Inspire 2 is no longer vibrating for any calls, texts, or any notifications. Is there a way to fix this issue?
13 REPLIES 13
@Bisqit Welcome to our Fitbit Community. Regarding the vibration issue for notifications that your Inspire 2 has experienced, I noticed that our team contacted via chat. Please reply to the email they sent you and they'll be happy to follow up and assist you accordingly.
See you around.
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
JuanJoFitbit, can you have someone from the team reach out to me?  I'm having the same issue.
Yes me too. It worked when I got it a week ago but after syncing my heart rate up these issues started up. Pls have someone contact me also. Thank you.  Juli
HI, I too am having similar issues. @JuanJoFitbit so hoping that this problem is able to be fixed or someone can contact me too.
I'm experiencing the same problem. Can your team send me an email yo help me overcome this issue?
Same issue here…please help. This seems to happen frequently, then starts up again on its own-quite frustrating as I’ve spent hours removing, restarting and reconnecting devices with no luck.
 Thanks
I have the same problem
Worked fine for 2 weeks then just stoped vibrating for calls and texts!!
Could someone contact me regarding this please
Can I get an email about getting help with this issue? Also having same problem Emilythomasbusiness@gmail.com
I'm having the same problem, too. My fitbit is brand new and this is super frustrating. It worked for the first few days and then today it didn't.
I received this reply from a Fit Bit moderator.  I'm getting the notifications again.
Thanks for the details shared in your post. I appreciate your efforts and recommend doing the following:
1. Make sure DND (Do not disturb) and Sleep mode are turned off in quick settings on your tracker. For more information, see How do I navigate my Fitbit device?
2. Make sure you set up notifications correctly. For more information, see How do I get notifications from my phone on my Fitbit device?
For complete troubleshooting tips, see Why didn't my Fitbit device alert me?
Hope this helps.
I had this problem and I had actually turned on Do Not Disturb by mistake ,
the icon is just under the water lock on the inspire 2.
Once I clicked on it and turned it back on everything worked fine.
Hope it's the same for you .
The customer service has gone way down!
