03-05-2024
07:57
06:15
ManuFitbit
03-05-2024
07:57
06:15
ManuFitbit
My Inspire 2 is not recording my sleep data accurately. Sometimes no data other times an hour and a half sleep at most. No sleep score. What's wrong?
Moderator edit: clarified subject.
03-06-2024 06:12
03-06-2024 06:12
Hi @Sydney425. Welcome to the community forums.
Thank you for sharing the inquiry regarding sleep.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Inspire 2 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.In case the problem is related to the Fitbit app, please try the following as well:
03-12-2024 08:57
03-12-2024 08:57
This happened to me also and after resetting the device by pushing the side buttons…..can’t remember the exact order. But it’s something like pressing the buttons on the sides so many times in a row, and then pressing and holding the buttons in until you see the smiley face. If you don’t know, then just Google it. Have a blessed day.
