10-27-2023
12:18
08:42
ManuFitbit
10-27-2023
12:18
08:42
ManuFitbit
Not tracking hrt rate, sleep has no data.zone minutes
Moderator edit: clarified subject
10-28-2023 07:44
10-28-2023 07:44
@Barbara.weiss a feature of the Inspire 2 is that it can be worn on a clip or on your wrist. It may be that your device is in "clip" mode. In that case, the heartrate monitor will not be turned on and you wouldn't get BPM, sleep tracking, or active zone minutes. To check this, press and hold both buttons on the sides of the Inspire 2. You'll get a list of settings. Swipe up until you get to the last one. It should say "On Wrist", if you want see your heart rate. If it says "On Clip", tap on that and change it to "On Wrist".
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
Best Answer10-28-2023 08:12 - edited 10-28-2023 08:17
Welcome to the forums @Barbara.weiss.
I'm sorry to know that you are experiencing this kind of difficulty with your tracker. Thank you for sharing the details about it.
Thanks @alexthecat for this current information provided.
@Barbara.weiss, if your tracker is not in clip mode and you are still having issues to record your heart rate, please see this article: What factors can affect my heart-rate reading on my Fitbit device?
In addition, try to restart your device as suggested here. After recording the heart rate correctly, you will be able to record sleep as well.
