05-28-2022
06:16
22:19
05-28-2022
06:16
22:19
At first my device recorded steps, heartbeat, target heartbeats reached, etc. Now it is only recording steps. Also no flashing lights on backside when I remove device. Device is at full charge. I bought it on Amazon and I am about to start a return.
05-28-2022 08:22
05-28-2022 08:22
Inspire has a setting to wear on a clip rather on wrist. In that mode, heart rate is turned off. Maybe you accidentally switched to clip mode.
Press both side buttons for a few seconds to bring up Quick Settings screen. Look for On Wrist / On Clip setting and make sure it is set for on wrist.
05-28-2022 08:22
05-28-2022 08:22
05-28-2022 10:58
05-28-2022 10:58
Thank you. Somehow my device was in clip mode.
05-28-2022 13:44
05-28-2022 13:44
Those Quick Settings seem to get changed by mistake fairly often, including 'Screen Wake' which affects screen turning on with arm lift.
Best Answer05-28-2022 15:12
05-28-2022 15:12
The two weeks that I have owned my Fitbit have been crazy busy. Hopefully this week I'll have time to review the owner's manual.
Best Answer05-28-2022 18:04
05-28-2022 18:04
Awesome! It worked! Thanks so much!
05-30-2022 01:57
05-30-2022 01:57
Thanks for the info about the On/Off Wrist function. I set the wrist function to ON and the green light turned back on and the Heartbeat functionality is now restored. Thank You!!
06-02-2022 02:41
06-02-2022 02:41
Thanks! This helped!
