07-03-2022
07:47
22:19
07-03-2022
07:47
22:19
My new inspire 2 is not calculating my sleep cycles
07-03-2022 12:56
07-03-2022 12:56
Hello @Pahilton
Look to make sure you haven’t accidentally disabled your heart rate. Also if your Inspire 2 isn't tracking sleep information please make sure you're sleeping more than 3 hours which are required in order to show sleep stages. Also, double check that your band is snug on your wrist and try using it in the other wrist for one night. Lastly double check that your Fitbit Inspire 2 is set to "On Wrist". Because when your tracker is set to "On Clip" certain features are turned off including heart-rate tracking, automatic exercise tracking, Active Zone minutes and Water Lock. To check this, press and hold the buttons on Inspire 2 and choose "On Wrist'" setting to ensure these features are turned on.
😃 Please let me know if this provides you an answer. Please come back and let me know.
07-03-2022 12:56
07-03-2022 12:56
Hello @Pahilton
07-03-2022 19:34
07-03-2022 19:34
@Pahilton look under the graph of your simple sleep, fitbit may already have told you why?
An example of mine from last week
07-03-2022 21:35
07-03-2022 21:35
09-16-2022 05:16
09-16-2022 05:16
I'm having this same issue. I just purchased the Inspire 2 for the sole purpose of the sleep stages and it doesn't show me that. I have checked all settings recommended. It's set to 'On Wrist'. I wear it up high and snug. The heart rate works for other tracking. I'm sleeping more than 3 hours. Battery is fully charged? I'm going to return the device if I can't get this resolved. Thanks!
09-16-2022 05:27
09-16-2022 05:27
I bought a versa 3 and it dyed y seem to have the same issue . Having said that I sent it back in favour of the garmin as it can store music but Fitbit removed that feature from the versa3 and make you use premium streaming services if you want music so I sent it back on principle although I did prefer some of the Fitbit features ,
