02-02-2022
00:06
22:51
02-02-2022
00:06
22:51
My inspire 2 is not picking up my sleep properly, not detecting when I was awake or restless etc. I’ve tried it on both hands and changed in setting which hand I’m using as well
01-02-2022 23:38
01-02-2022 23:38
How do I increase my readiness score
02-02-2022 09:07
02-02-2022 09:07
Are you using Apple IOS app? Did the problem coincide with your app update that they released 1/26/22? My nighttime details, sleep stages, HRV and breathing rate as well as daily readiness scores no longer work since 1/26/22.
02-02-2022 09:13
02-02-2022 09:13
Yeah I am and it only worked for the first couple nights but I’ll try updating it see if that changes anything
02-02-2022 09:13
02-02-2022 09:13
thank you
02-02-2022 13:59
02-02-2022 13:59
Mine was working UNTIL that update. I don’t recommend it. Now my sleep stages, HRV, nighttime breathing rate and readiness scores are broken too.
02-02-2022 14:37
02-02-2022 14:37
Awhh Okayy thank you I won’t do it I did used to click begin sleep now on my phone so I don’t know if that had anything to do with it so tonight I’m going to just fall asleep and see if it picks it up
02-03-2022 15:52
02-03-2022 15:52
Hi there, @SadieTweddle. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2. Thanks for jumping in @MLB44.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that said, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
02-04-2022 18:36
02-04-2022 18:36
Thank you! I have read the manual and unfortunately these fixes did not apply and were not helpful in resolving my issue but hopefully will help someone else.
02-25-2022 14:12
02-25-2022 14:12
@MLB44 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
