05-06-2023 20:12
05-06-2023 20:12
The screen on my Inspire 2 is always dim. I'm pretty sure it's dimmer than when I first got it. The setting is not set to be dim. I have restarted, reset etc.
05-06-2023 21:30
05-06-2023 21:30
Make sure you are not in Sleep Mode, which intentionally keeps the display dim. Does the display come on with wrist turn? If not, probably in Sleep Mode.
05-07-2023 00:44
05-07-2023 00:44
Yes it will turn on when I turn my wrist but it's dim
05-07-2023 06:24
05-07-2023 06:24
@63Blonde wrote:Yes it will turn on when I turn my wrist but it's dim
Then it is not in Sleep Mode, so my suspicion was not the answer.
