03-21-2022
09:33
22:39
03-21-2022
09:33
22:39
is there something you can do to see the watch face outside? It’s sad that I can only see it indoors.
06-05-2022 14:54
06-05-2022 14:54
Has your Inspire 2 been on sleep mode? I don't know what other thing could be affecting the brightness.
03-25-2022 08:19
03-25-2022 08:19
Hi there, @Siern. Welcome to the Community Forums. Thanks for the details provided in your post. I understand how you must be feeling.
If you're talking about display brightness, Inspire 2 has the option to turn off dim brightness on the Settings app. You can find this and other details about Inspire 2 features here: Inspire 2 Manual. You can use this model outdoors.
Hope that helps.
03-27-2022 05:28
03-27-2022 05:28
I have turned the dimness off and it still does not work. You just can’t see the face outside.
03-28-2022 13:04
03-28-2022 13:04
i agree - seems pointless trying to look at screen on a sunny day - you can't see a thing 😞
05-27-2022 08:48
05-27-2022 08:48
My Inspire 2 screen is so dim outside that there is no way I can read it, even though the dim setting is off.
Is there truly no fix for this problem? Can't this problem be addressed in an update?
What good is a fitness cracker if you cannot see the screen outside?
05-30-2022 23:40
05-30-2022 23:40
It would be more helpful if you told us how to do it. I thought community was for things we don't understand in instruction manual. Anyone can tell is yo look it up
06-02-2022 11:29
06-02-2022 11:29
I don’t see the dimmer in settings.
06-05-2022 14:54
06-05-2022 14:54
06-05-2022 16:57
06-05-2022 16:57
My watch was not in sleep mode. And since I posted, my watch has completely died. In less than a year!
06-05-2022 17:08
06-05-2022 17:08
@Siern Oh no! I'm sorry to hear that. You may be able to get a replacement.
Thanks for the "best answer". I truly appreciate it.
06-10-2022 10:21
06-10-2022 10:21
I have the same issue. The Dim Screen and Sleep Mode are both off in my Inspire2 but I cannot read the Fitbit outdoors, not even in cloudy days This points out to a serious design failure.
06-10-2022 12:11
06-10-2022 12:11
Does the Inspire have the step counter ???
Best Answer06-10-2022 14:19
06-10-2022 14:19
Best Answer06-11-2022 15:39
06-11-2022 15:39
This is my 2nd fitbit. Other was a versa. Cannot read outside at all. There is no option in settings app for dim screen. So frustrating. One of the most important things should be the easiest to adjust. Will nit purchase another fitbit.
Best Answer06-11-2022 16:45
06-11-2022 16:45
06-11-2022 17:25
06-11-2022 17:25
06-11-2022 17:26
06-11-2022 17:26
Best Answer06-11-2022 18:32
06-11-2022 18:32
Best Answer06-11-2022 19:52
06-11-2022 19:52
06-12-2022 01:36
06-12-2022 01:36
Choosing one's favourite clockface helps but why do so many of the options dim or overlap the minutes? I know what the hour is so I need to see the minutes bright and clear.
