09-17-2024
17:27
11:22
LizzyFitbit
09-17-2024
17:27
11:22
LizzyFitbit
Is there a setting on the inspire 2 to make the screen brighter? It's unusable outdoors and barely usable indoors. I already checked and the dim and sleep settings are off.
Moderator Edit: Clarified subject and updated label
10-02-2024 04:59
10-02-2024 04:59
Hi, @gjosefsberg welcome to the community, allowing you have set the dim screen to off also ensure the Do Not Disturb and Sleep mode settings are off. The monochrome screens are not as bright as the newer colour screens on the Inspire 3 but are useable in all but the brightest conditions. I assume you are using the latest SW v 124.84.
I hope this helps, let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
