07-24-2023
01:42
05:00
07-24-2023
01:42
05:00
The screen on my Inspire2 keeps going on and off.
I have reset as a new device several times. Tried "Reboot". Paired with bluetooth.
Logged out and in again.
Nothing helps. The screen is still flashing on and off and flattens the battery very quickly.
Any help would be appreciated, thank you
07-24-2023 05:03
07-24-2023 05:03
Hello there, @OliviaJosh2023. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work and since your Inspire 2 keeps flashing the Fitbit logo, please try the following:
If none of the above works, please follow @NellyG's advice and chat with us online or give us a call. Click here to get connected.
Best Answer07-24-2023 03:38
07-24-2023 03:38
Hi @OliviaJosh2023 If it is still covered by warranty, contact Fitbit Support .u fortunately if it is no longer covered by warranty then there is probably nothing you can do.
Helen | Western Australia
Best Answer07-24-2023 05:03
07-24-2023 05:03
Best Answer07-27-2023 10:34
07-27-2023 10:34
Thank you for your reply.
I have delayed answering because although this helped and is much better, I just wanted to chevk that it stays jush flashing on and off randomly now and again. It is much better and I can live with it until I can afford to buy a new one.
Thank you very much
Kind regards OliviaJosh
