06-30-2021
12:27
23:04
06-30-2021
12:27
23:04
I just got an Inspire2 last week and am disappointed that I can’t see the screen outdoors. What good is it for tracking when you can’t see it! Thinking of returning and getting a cheap fitness watch I’ve had that screen is visible!
06-30-2021 14:00
06-30-2021 14:00
This is just one of the sticky little things about Fitbit that makes me crazy.
My Inspire randomly decides to notify me or not about needing more steps to complete an hour.
It challenges me to perform some stunt when I have not asked for any such motivation.
It vibrates repeatedly sometimes (like for the above mentioned challenge) when I am outside working, can't see what the screen says, have to take off my gloves and find some shade to read the screen, sometimes have to take off the Fitbit to get it to reset.
It will reset or unset or make some change if I bend my wrist and it thinks I am pressing the sides (I have tried wearing it higher on my wrist and a little looser so this won't happen but it still does).
Here's what I want to see when I turn my wrist over:
A, What time it is
B. How many steps I have completed.
It would be so great to be able to see that outside. Or inside. Just that. If I want to see any of the other stuff I'll ask.
I think these trackers have been poorly designed, haphazardly manufactured, and are overly complicated. They also have pretty short lifespans so that you will be prompted to buy the newest way overpriced version.
This will be my last Fitbit. It was fun for a while to keep track of activities but now it's not worth the trouble with all the little quirks. My first two Altas were much simpler but also not without problems- terrible wristbands, short lived batteries, very small screen.
It will probably wear out in the next year or, more likely, I will place it carefully on a hard surface and smash it with a hammer.
Too bad Fitbit, I was hoping we could be friends.
06-30-2021
16:04
10:25
AndreaFitbit
06-30-2021
16:04
10:25
AndreaFitbit
I bought this Fitbit because I thought it would be better than my previous cheaper fitness watch. Disappointed that it can’t do all that my old one (that lasted over 6 years and still works but because I had to glue my band back on) I decided to try a new watch. My old watch could swim in it (without having to turn a water lock on) could see clearly outdoors, and notifications could be changed on or off. The only thing I like about the Inspire 2 is that it doesn’t turn on at night when I move my arm so it doesn’t disturb my husband’s sleep.
Moderator edit: removed personal information.
Best Answer07-01-2021 13:41
07-01-2021 13:41
Welcome to the Fitbit Community, @Sroden1 and @youmowgirl. I really appreciate your comments regarding Inspire 2 screen.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on what you share here.
You can vote for the idea Visible/brighter Display for Outdoors - Inspire Series.
Keep on visiting the forums.
04-18-2022 14:13
04-18-2022 14:13
I can't believe anybody would sell or buy anything that can't be used in daylight hours!
I got my first fitbit today as a present and I've had to wait until dark to see it. What is the point???
04-19-2022 00:35
04-19-2022 00:35
I found in settings to turn dim screen off when outside. I turn dim on again when indoors. It seems to help but obviously, cupping the screen with your hand to avoid direct light helps as well. (I thought my inspire was broken when I couldn’t see it outside with dim screen on.)
04-19-2022
06:43
07:40
04-19-2022
06:43
07:40
Welcome to the Fitbit Community @Notimpressedkei. Thanks for getting back to us and for sharing your advise to turn dim screen off when outside @SunsetRunner.
@Notimpressedkei, please turn dim screen off to see it outdoors.
