11-27-2020 12:00
11-27-2020 12:00
I bought two inspire 2s. My wife’s one has a nice bright screen. Mine is very dim and difficult to see when outdoors. In fact it’s useless to me. I have to rely on the app for information. Is there a way to make the screen brighter?
08-27-2022 15:09
08-27-2022 15:09
08-27-2022 22:08
08-27-2022 22:08
Ok, so now I'm seeing it's a common issue with this version. So now what? Do I have to buy a new Fitbit or will it be replaced?
08-29-2022 08:56
08-29-2022 08:56
08-29-2022 16:29
08-29-2022 16:29
Same here -- I think it's time to switch brands. I'll be looking so if anyone has any recommendations LMK.
08-31-2022 05:36
08-31-2022 05:36
Holding both sides makes no difference. Can't see anything unless I plug it in.
08-31-2022 05:37
08-31-2022 05:37
I went through Chat too but it was a nightmare as I can't see anything to follow the instructions. Eventually they just cut me off!
10-09-2022 04:28
10-09-2022 04:28
Well it worked perfectly when it was purchased. Not even a year and you can barely see even indoors.
Auto dim and sleep off
10-09-2022 05:40
10-09-2022 05:40
Impossible to do. I can't see anything on the screen to switch off!
I can feel the vibration but there's nothing to see.
10-11-2022 17:31
10-11-2022 17:31
Hi, my sister and I are having the same dim screen issues. For some reason I can not get into the quick settings. All I see under mine is the Water Lock setting. I tried looking for step by step instructions in the manual but couldn't find anything.
10-11-2022 19:52
10-11-2022 19:52
They don't seem to have a solution, and don't care much. They offered me a small discount on a new fitbit. Frankly, I'm not impressed and don't want to pay more to this company that I no longer trust.
10-11-2022 19:53
10-11-2022 19:53
Mine too. It's become impossible to use. I'm so disappointed in the product and even more disapointed in the company's responses
10-12-2022 02:36
10-12-2022 02:36
11-10-2022 10:59
11-10-2022 10:59
Thank you! This worked for me!!
11-18-2022 15:27
11-18-2022 15:27
Mine does not work even if the lights were off. So stop saying that it cannot be seen in daylight!
11-18-2022 15:30
11-18-2022 15:30
Fitbit does not seem to help as it seems to be a problem with the watch itself. I can hardly see the time on mine. I have doene everything that I was asked to do many, many times. So don't expect any help from the manufacturer.
11-18-2022 15:31
11-18-2022 15:31
I have the same problem and no help from Fitbit.
11-18-2022 15:32
11-18-2022 15:32
Common problem with Fitbit it seems and they cannot fix it!!
11-18-2022 15:33
11-18-2022 15:33
I will not buy a Fitbit again as they don't seem to do anything about it!!
11-20-2022 12:45
11-20-2022 12:45
I contacted Fitbit customer service directly . Not sure of warranties etc elsewhere, but I'm in Australia.
I was offered a full replacement of my Inspire 2 or 50% off and upgrade to other Fitbit.
Good outcome
11-23-2022 10:04
11-23-2022 10:04
Sorry but you don't know what you are talking about. I have the same problem. It started a week or so ago. I am trying to read the screen INSIDE in dim lighting and hardly can see it. As I turn Dim Screen on and off there is NO change in brightness. As I see it Fitbit has a pronblem and there so calle tech support doesn't have a clue.
