Inspire 2 stopped tracking my heart rate
My heart rate feature stopped working. Sleep info will not work ,resting heart rate feature will not work I have cleared cache as will have rebooted device, then as well as reinstall the Fitbit. Please advise how to restart the heart rate feature.  Thanks
1 REPLY 1
@Ddavis64  One feature of the Inspire 2 is that you have the option to wear it on your wrist or on a clip. If it is set to wear on a clip, the heart rate monitoring will be turned off and the green lights won't be on.
To check this, press and hold both buttons on the sides of the Inspire 2. You'll get a list of settings. Swipe up until you get to the last one. It should say "On Wrist", if you want see your heart rate and sleep stages. If it says "On Clip", tap on that and change it to "On Wrist".
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
