04-16-2023
06:02
07:39
04-16-2023
06:02
07:39
So I’ve had my inspire 2 for a few days. First two nights my sleep stages turned up and I got my sleep score on one night. Now neither of those are popping up. Any ideas why? Thank you!
04-17-2023 07:42 - edited 05-30-2023 04:06
Hi there, @ZeroDullBits @Psyched. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit devices before reaching out.
As a first approach, I'd recommend trying the following steps to make sure your heart rate is working as heart rate reading is key to get your sleep data accurately:
Also, for more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that in mind, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Best Answer04-17-2023 07:18
04-17-2023 07:18
My Inspire HR stopped providing a sleep score two weeks ago. Everything else works fine. The last time this happened was after an update. I have tried all of the usual fixes, but none have worked.
Best Answer04-30-2023 17:23
04-30-2023 17:23
Thank you for the response. I have tried this intervention several times, but still have no sleep scores. This has been going on since 4/6. Do you have any more suggestions? Thank you!
05-26-2023 08:23
05-26-2023 08:23
Hi, I have been having this issue for a week now, it started having it a few days before and now it won't stop. I have tried all of the interventions you have listed multiple times and none of them seem to be working. I have had my Fitbit for about two and a half years so I am wondering if it's just reaching the end of its life cycle? How long should I expect it to last? The screen is very dim compared to what it used to be even at full charge and with the dim setting off. Thanks for any help!
05-26-2023 22:09
05-26-2023 22:09
Question was specifically asking about Inspire 2 not showing sleep data periodically, but answers seem to be for Inspire 3. Please detail steps to take for Inspire 2.
05-28-2023 15:22
05-28-2023 15:22
My Inspire 2 is still not providing sleep scores on a regular basis. I get the occasional sleep score, but then nothing for days.
07-09-2023 00:45
07-09-2023 00:45
I m having the same issue with inspire2. After I bought it only did the sleep synch for 2 days and then stopped working. Everything else works fine. I only use this for sleep. Please some reply. I have relied several things but still not work
