09-07-2024
11:20
08:17
09-07-2024
11:20
08:17
I did an update a couple of weeks ago and haven’t gotten a sleep score since. How can I fix this!
09-10-2024 08:25
09-10-2024 08:25
Hi there, @Gingercookies. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Inspire 2 has stopped tracking your sleep score. I understand your concern, I will do my best to help you with this!
As a first approach, please keep in mind that you must see sleep stages in order to see your sleep score information. If you're not receiving sleep stages, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
If the above doesn't help you, I'd suggest resetting the heart rate (as the HR is key to receive your sleep data) settings by following the steps below:
09-21-2024 20:31
09-21-2024 20:31
Same problem
09-29-2024 22:39
09-29-2024 22:39
Hi I had the same issue after syncing with Google. I deleted my app. Then reinstalled it. When asked to login I chose Fitbit not Google sign in. I rebooted my watch. I then used "forget" option on my Bluetooth and searched and paired device again. Once synced, everything reappeared on my app. Hope this helps.
