02-13-2023
08:20
07:22
02-13-2023
08:20
07:22
Wore my Inspire 2 in the pool for about 1/2 hr. When I got out the face did all kinds of funny things. I dried it off - and the screen was blank. Have tried recharging and restarting - still blank. Is it dead? Did I kill it?
02-13-2023 08:24
02-13-2023 08:24
Hi @jatini see page 48 of the user manual. There may be some residual moisture in the Inspire 2. Try putting it in a dry bowl of rice for a day or two. Then clean all contact points and try to charge and reset it. If it doesn't spring back to life, get with customer support if you're under warranty.
02-13-2023 08:41
02-13-2023 08:41
Thanks - it's actually been drying out for over a month and no longer under warranty. guess contacting customer support won't hurt though.
02-13-2023 08:49
02-13-2023 08:49
It's possible charging it with moisture in it fried the battery. Support can tell you if there are any available options.
