06-24-2022
15:33
22:19
06-24-2022
15:33
22:19
I cannot swipe the home screen. When I press the side buttons I get "water lock". Then I tap 2 times to unlock. And the screen goes blank...And I am back to square one. I unlocked all day yesterday and made no progress.
06-25-2022 05:33 - edited 11-16-2023 03:00
Hi there, @Gezunt. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out.
It seems that your Inspire 2 is still stuck on water lock. With that being said, please firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
Hope that helps.
Hope that helps.
06-25-2022 13:42
06-25-2022 13:42
Looking for the same question and it worked! Thanks
Best Answer06-26-2022 10:58
06-26-2022 10:58
Best Answer06-26-2022 12:19
06-26-2022 12:19
Me too. Device vibrates often showing the water lock. Draining the battery in a day.
Best Answer06-26-2022 12:21
06-26-2022 12:21
Tried this multiple times. No luck. Started 3 days ago. I looked at various chat rooms online. Seems like lots of people are having the same problem.
06-26-2022 12:40
06-26-2022 12:40
Yes. I put down my Fitbit and tried another product because I was having this problem. It wasn't any better. Two things. One, water lock popped up when I was setting an exercise mode (not Swimming), and two, the Water Lock option no longer shows up on my stats list (steps, unknown stat, bpm, etc.). It used to be the last item on the list. I'm glad it's gone and I hope it stays gone from that list. My questions are:
Why did it pop up in my exercise options? And
Will it go away completely if I remove Swimming from my exercise list?
