07-03-2022
15:01
22:19
07-03-2022
15:01
22:19
The side buttons aren't working and it keeps randomly flipping to the menu with Water Lock and other options. It started this an hour or so after being out in the garden. Is it fixable or busted?
07-04-2022 11:19 - edited 11-16-2023 04:16
Hi there, @BRae11. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2.
It seems that your Inspire 2 is still stuck on water lock. With that being said, please firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
Hope that helps.
Best Answer07-04-2022 11:19 - edited 11-16-2023 04:16
Hope that helps.
