06-10-2023
03:03
12:09
JuanFitbit
06-10-2023
03:03
12:09
JuanFitbit
Sometimes never, but always "sit tight" for 5 or more minutes..
Moderator edit: clarified subject.
06-10-2023 07:11
06-10-2023 07:11
Hi @PerryLowell. It's good to see you around the community.
Thanks for your feedback regarding synch.
Let me invite you to our Health & Wellness board where you can make new friends, create topics and share your experience while reaching your goals.
Best Answer06-11-2023 12:08
06-11-2023 12:08
@PerryLowell , Nice to see you here. Thank you for your feedback.
Have you tried the steps here to see if you can improve the time during the sync.
Keep in mind, that the syncing is dependable of your internet connection, and how far back your last sync was. It'll take you longer if you sync the Inspire 2 every 2nd/3rd day as if you sync at least 1-2 a day.
Also make sure that you don't have anything else connected to your phone via bluetooth.
You can also try turning your phone on/off.
Best Answer06-11-2023 12:48
06-11-2023 12:48
I synch at least once a day. My network is a 5G. It's the only bluetooth device connected, and I've turned BT off and back on prior to synching.
It just tells me to sit tight and once I get that message it never finishes that synch - even if the synch worrked an hour prior.
It's very weird.
Best Answer06-11-2023 13:29
06-11-2023 13:29
@PerryLowell , Thank you for your reply!
Please on your phone go to settings> Apps> Fitbit App and clear the Cache.
Restart your phone (off/on)
In the meantime, please restart the Inspire 2.
When the phone is on again, open the Fitbit app.
Try to sync the Inspire 2 with the app .
13:40
12:45
RodrigoMFitbit
06-11-2023
13:40
12:45
RodrigoMFitbit
Thanks, I'll give that a try.
Nope, no joy.
The "fix it" advice doesn't fix it, either.
15:27
08:24
06-11-2023
15:27
08:24
@PerryLowell , Thank you for getting back to me and for the pictures shared.
Please sync your Inspire 2, even if it takes 5 minutes, so that no data gets lost.
Please follow these steps as a 1 time exception.
On Inspire 2, open the Settings app Clear User Data.
When prompted, press the screen for 3 seconds, then release. When Inspire 2 vibrates and you see the clock screen, your data is erased.
Record the steps or any activity and try to sync afterwards.
