08-12-2022
15:23
22:11
08-12-2022
15:23
22:11
Hi, my inspire 2 screen is very very dim. I need to cup my hand around it to even see it indoors. Dim screen and sleep mode are off. I’ve also tried to restart it and change the clock face. None of this helped. Any suggestions?
08-13-2022 05:48
08-13-2022 05:48
You are not alone. Litterally hundreds of poeple have this issue. It will get worse, until you cannot even see it in a dark room.
Seems FitBit do not care, or don't want to admit a serious design fault. I will not buy another fitbit due to this.
Read this fast, as I expect (as usual) for my post to be removed, due to negativity
08-13-2022 05:48
08-13-2022 05:48
08-13-2022 08:14
08-13-2022 08:14
Thanks. I kinda thought that it might not be fixable.
Best Answer08-13-2022 11:05
08-13-2022 11:05
I can’t see my screen when I’m outside & can barely see it inside. I know many others who have this same issue, after making sure the settings are correct. It’s frustrating that Fitbit isn’t addressing this issue. What good is a fitness tracker that we can see?
08-16-2022 11:52
08-16-2022 11:52
I sincerely hate this thing. Previous Fitbit, more expensive, died on me so hubby bought basic one for me. Can’t read display AT ALL. It’s always too light. Doesn’t matter where I am.
08-16-2022 15:32
08-16-2022 15:32
I have a brand new (4 days old) Inspire 2 and I can't see the display at all when I'm out, or even in. Is there anything I can do? Has anyone got any suggestions?
Could I also ask if there's a way to get the Inspire 2 to do fireworks or some kind of fanfare when 10k steps are reached?I loved it with the Alta HR but the Inspire 2 doesn't seem to do it, unless there's something I should have done that I haven't.
Thanks all.
08-21-2022 19:41
08-21-2022 19:41
I called customer support on this last week. Since my inspire 2 is just over a year old and out of warranty, they offered me $50 off on a Charge or Luxe
model. I did not take them up on their offer. Their price was such that I would only be saving about $20 off the price I could find elsewhere and I do not want a more feature filled model..
I am hoping my Inspire 2 won't die completely until the Inspire 3 is available. It is rumored that Inspire 3 may be available a bit later this year and will include an improved and colored display.
Best Answer08-22-2022 01:13
08-22-2022 01:13
08-22-2022 01:22
08-22-2022 01:22
Hello everyone and thanks for your replies and support. I've only had my Inspire 2 for less than two weeks so I think I'll contact customer support and see what they have to say. I'm very disappointed to say the least!
08-25-2022 00:50
08-25-2022 00:50
I don't know if it's still an issue for you, but the last firmware seems to have "unlocked" the dim setting for me.
Best Answer08-25-2022 05:57
08-25-2022 05:57
Hello - that sounds encouraging about the firmware. Could you direct me to where I could find that update? Thanks so much - feeling hopeful now!
Best Answer09-18-2022 06:03
09-18-2022 06:03
Didn't work for me. 😞
I wonder if that's why they have launched the Inspire 3 so soon.... if this is the fix, perhaps they should be replacing all the defective Inspire 2 models out there....
09-18-2022 06:43
09-18-2022 06:43
09-18-2022 09:03
09-18-2022 09:03
Hello All. Here’s what I did. Because I’d only had the Inspire 2 for three weeks and it was so hopeless, I sent it back to Fitbit and got a refund. I then got an Alta HR from eBay, the same as the one I had previously. It’s working brilliantly, life is back to normal and I’m happy! The Alta isn’t brand new but is very good and even if it lasts 6 months I’ll be happy. It gives me a chance to think about where to go next - definitely not the Inspire 2!
10-24-2022 10:42
10-24-2022 10:42
Was it? I haven’t found a way yet
Best Answer10-24-2022 15:07
10-24-2022 15:07
Best Answer10-25-2022 03:06
10-25-2022 03:06
The fact that the fitbit which is barely 2 years old and has issues which are not addressed i will not buy another fitbit brand. There are other brands
02-01-2023 20:22
02-01-2023 20:22
Who decides what the best answer is? It did not address the fundamental issue. Is there a way to roll back the firmware updates as this is most likely the issue as the face is much brighter showing battery progress while charging but reverts to dim when fully charged and unplugged.
Best Answer02-06-2023 14:14
02-06-2023 14:14
This has been my #1 irritation with the device. I recently figured out that I must have to keep my phone handy to read the numbers. But I don't know if they will "talk to each other" when out of cell and wifi range.
