03-30-2022
11:30
22:39
03-30-2022
11:30
22:39
My Fitbit Inspire 2 won't notify me of any notifications. No vibration at all for calls, texts or the setting to remind me to move hourly. Nothing shows up for those on the Inspire 2 either. I have a Samsung S10. I've checked all the settings I know to check. What am I missing?
04-01-2022 06:21 - edited 04-02-2022 04:10
Hi there, @Donfab. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out.
As per the description of your post, it seems like your Inspire 2 might be in sleep mode or DND. For more information, see Why didn't my Fitbit device alert me?
Hope that helps.
Best Answer04-01-2022 19:10
04-01-2022 19:10
04-02-2022 04:14 - edited 12-11-2023 04:04
@Donfab Thanks for the details provided. I understand why you're feeing frustrated.
When you turn off the setting,(either it may be sleep mode or DND) the icon appears dim with a line through it.
When the do not disturb setting is on:
When the sleep mode setting is on:
You can't turn on do not disturb and sleep mode at the same time. For more information, see How do I navigate my Fitbit device?
See you around.
Best Answer04-03-2022 06:21
04-03-2022 06:21
DND and Sleep are both turned off and I'm still not able to get notifications. Is there anything else I can try?
