Inspire 2 won't change the time after traveling
ANSWERED
I traveled to a different time zone and my Inspire 2 adjusted to the change but when I came home, it won't adjust back!  So it is two hours off. How do I fix it?
1 BEST ANSWER
Accepted Solutions
@78748 welcome to the Community! My Fitbit did that to me once when I crossed timezones too. You can find instructions for fixing the time here
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
5 REPLIES 5
Your watch will change the time only if you have time zone changes in the automatic mode on your mobile device and you sync your watch in the Fitbit app. If those settings are not automatic, then you have to manually change it on your device and then sync your watch accordingly.
Thanks for adding this detail, @78748. I'm sure this will help other users having similar questions.
See you around.
mine is not resetting.  It reset when I went ,but hAS NOT RESET WHEN i RETURNED  How do I manually reset
Same thing happened to me.
How do you manually reset?
