02-15-2023
02:52
07:57
02-15-2023
02:52
07:57
My Inspire 2 has worked fine for 4 months since purchase. But after I got up briefly in the middle of the night, the green light disappeared and it stopped monitoring heartbeat and sleep. The setting now shows as ‘On clip’ but when I try to change it to ‘On wrist’, I just get a greyed-out message saying ‘Enable On wrist?’ which is unresponsive to being tapped. I have tried rebooting, charging, and cleaning the sensors, to no avail. What can be done please?
Update: Phoned Fitbit support as no responses on here. Very helpful guy, took me through uninstalling and reinstalling from scratch and it worked after the reinstall
02-16-2023 08:02 - edited 01-31-2024 07:15
Hi there, @Mike4343. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Inspire 2 before reaching out.
I'm glad to hear that our Support Team was able to help. I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Best Answer03-25-2023 19:42
03-25-2023 19:42
This just happened to me this morning and I can’t change it back. How did you find a phone number for Fitbit support?
Best Answer03-26-2023 02:15
03-26-2023 02:15
For some unknown reason the ‘Community’ will not permit me to reply with the phone number - my message isn’t accepted! Can’t remember where I found it now unfortunately.
let me try giving you a simple code. If a = 0, b = 1, c= 2 etc, the number is
aca ddij gebg
Sorry to have to do it this way!
Hooe you see this before Big Brother deletes it
Best Answer03-26-2023 09:06
03-26-2023 09:06
@Cjmmke Here are all the options for ways to contact Support
Laurie | Maryland
